T-5 problem
Old Aug 13, 2007 | 08:16 PM
BGooch's Avatar
BGooch
Default T-5 problem
Hey everyone, I have a 1990 GT with a T-5 tranny it doesnt want to go into 2nd and grinds a little going into 3rd It has the original self adjuster clutch cable mechanism and what I beleive to be an aftermarket hurst short throw shifter.I need to know if my problem is most likely caused by the clutch mechanism or if it could be a shifter problem or if it would be the synchronizers in the tranny. I dont want to go through the trouble to pull the tranny if it is something wrong thats not in the tranny. thanks for all the help ahead of time. Barry
Old Aug 14, 2007 | 11:07 AM
GreyStang's Avatar
GreyStang
Default RE: T-5 problem
Sounds like a bad synchronizer problem.. which would mean the tranny needs to be removed & opened up [:@]
If you can put it into 1st gear no problem then your clutch is fine. I'm not sure if a badly adjusted shifter could do the type of problems you're describing,,,
Old Aug 14, 2007 | 12:47 PM
945LSTANG's Avatar
945LSTANG
if it doesnt grind in every gear then its not your linkage. sounds like bad syncros. as greystang stated earlier, your tranny will have to be removed and opened up.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
