airbag terminal????
Old Aug 17, 2007 | 03:48 PM
Metalrain's Avatar
Metalrain
Default airbag terminal????
Ok my air bag light is flashing code 52 which is low back up supply voltage. and I got a print out on how to check everything it says to check pin 15 and pin 3. my question is where is the terminal that has these pins located under hood, dash, steering wheel or kick panel?
Old Aug 17, 2007 | 04:28 PM
Metalrain's Avatar
Metalrain
Default RE: airbag terminal????
BTW its a 94 v6
Old Aug 17, 2007 | 04:39 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
Check pin 15 and 3 at what connector? Could you elaborate?
Old Aug 17, 2007 | 04:59 PM
Metalrain's Avatar
Metalrain
what connecter is my question. I printed off a troubleshooting chart and it asks what the resistance is between pin 15 and 3.(circut 611w/o and 612p/o both should be a open circut to ground when diagnostic monitor is disconnected) But it dosent say where the connector is.
Bokeo
Oct 10, 2015 08:28 PM
ChampInSD
Oct 2, 2015 04:55 AM
logan409
Sep 26, 2015 07:43 PM
rksnow1
Sep 14, 2015 08:46 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
