cylinder 5 misfire please help
Old Aug 23, 2007 | 01:54 PM
mrpres_01's Avatar
mrpres_01
Default cylinder 5 misfire please help
99 Mustang GT 35th anniversarylimited edition 5spd.
Well recently I decided to wipe down and clean the engine compartment and clean the battery terminals. The problem is that I got spilled a little water over the heads right where the "coil over plug" systems are at. I cleaned everything up as I thought,but the next daythe enginestarted to sputter. Turns out cylinder 5 was misfirring which just happens to be the one closest to the battery. I removed the coil pack thinking that a little moisture still resided but to my suprise was antifreeze in the hole with the spark plug submerssed in it. I have never seen this before so I do not know what is causing it. I cleaned everything out but the sputtering still exists. HELP!!!
Old Aug 23, 2007 | 05:16 PM
blackstallion666's Avatar
blackstallion666
Default RE: cylinder 5 misfire please help
first your gonna have to fix the leak then install a new plug and coil. when the coil is submersed in water or coolant it over stresses it and causes it to fail.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
b8checker
Oct 8, 2015 12:55 PM
Dathan
Oct 5, 2015 05:52 AM
b8checker
Sep 30, 2015 07:11 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
