unleaded gas
Old Aug 25, 2007 | 04:30 PM
dlowry's Avatar
dlowry
Default unleaded gas
Just bought a 1965, 260 3 speed convertible, can I use unleaded fuel in the vehicle?
Daryl Lowry
Wichita, KS
Old Aug 25, 2007 | 07:43 PM
Chopper's Avatar
Chopper
Default RE: unleaded gas
I ran unleaded gas in a '70 Cutlass and had no problems,other than detonation under hard acceleration when using 87 octane.This was a 350 ci engine with 10-1 compression.Valve seat wear never was a problem and shouldn't be for you unless you run the crap out of it all the time.
Old Aug 26, 2007 | 06:09 AM
corvetteguy's Avatar
corvetteguy
yes
Old Aug 26, 2007 | 02:50 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Unless you're racing/running hard, you'll be fine with unleaded.
Old Aug 26, 2007 | 07:59 PM
67mustang302's Avatar
67mustang302
Yeah it does fine if it's kept under 3,000rpm and doesn't see extended preiods of use frequently(long commutes, road trips etc). If you plan on spinning the r's and building power and using higher seat pressure, then you'll want hardened seats
Old Aug 30, 2007 | 02:29 PM
boddvt66's Avatar
boddvt66
the lead in the gas was in there for a reason and that was to protect your valves. go to any automotive store and purchase unleaded gas additive, add that to your unleaded gas and you will be ok.
Old Aug 30, 2007 | 02:34 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: boddvt66
+1 ...anyone care to remember the reason??? Lubrication. Unless you have hardend valves and valve seat in your, run a lead additive in your unleaded gas or have your heads converted if they aren't already.
Old Aug 30, 2007 | 08:37 PM
MooseStang88's Avatar
MooseStang88
I had a 66 and a 68 and always ran unleaded with no problem. Every once in awhile run the higher octane and buy a octane booster. At least thats what I did and never had an issue, ran the heck out of the 68 too..
4cylinderplus2
Oct 9, 2020 07:45 PM
Sixer4Life
Oct 12, 2015 04:26 AM
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
