electric fan wiring, help!
Old Feb 8, 2005 | 06:51 PM
luckythirteen13's Avatar
luckythirteen13
Default electric fan wiring, help!
ok, the directions are pretty straight forward. but it is designed to turn the fan on when the a/c goes on. it says i need to hook one of the wires to the "a/c clutch". what is that? in the picture im holding the only wire coming from my a/c pump.....is that the one?
Old Feb 8, 2005 | 11:06 PM
99saleen351r's Avatar
99saleen351r
Default RE: electric fan wiring, help!
Thats the clutch wire there is only one wire that goes to it.Are you adding an extra fan? If so you want it on all the time dont you or at least when the other fan comes on?
Old Feb 9, 2005 | 01:23 AM
luckythirteen13
im replacing the belt driven fan with an electric one. the idea is that the fan will be off unless the engine is over 180* or the a/c clutch is activated.
Old Feb 9, 2005 | 02:44 AM
99saleen351r
when the engine goes over 180 it has nothin to due with the ac compresser.
Old Feb 9, 2005 | 04:53 AM
luckythirteen13
ya i know. the thing that turns the fan on has two different ways/reasons for turning it on.
1. when the engine is at 185*
2. when the a/c is on regardless of what the engine temperater is. if the car is running at 100* and i turn the a/c on, the fan is supposed to turn on. (fyi, the engine will never run at 100, that was just an example)
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
PaulH2
20
Jan 31, 2016 09:48 AM
Dathan
Oct 5, 2015 05:52 AM
Sep 25, 2015 09:06 AM
