Headlight help
Old Sep 6, 2007 | 12:04 AM
stangsta95's Avatar
stangsta95
Default Headlight help
i have a 95 Gt im trying to get the lights off ..i see a few bolts but not sure if there it..any one kno how many there are or if the the lenses come apart? i have water in one..and im tryign to clean them up to make em look clear..there all yellow..any input welcome..thanks
Old Sep 6, 2007 | 12:11 AM
stangsta95's Avatar
stangsta95
Default RE: Headlight help
bump
Old Sep 10, 2007 | 07:38 PM
94Yellow50's Avatar
94Yellow50
its real simple...just fold up the plastic cover flaps...and you'll see two nuts holding teh corner lights in...untighten those and pull them out...then the actual headlight is held in with three pins...one..i think the top one pretty sure..has a metal clip that needs to be pulled straight up...the other two are just a pin stuck through a hold with deals that spread out once through the hole...u just squeeze those and push the pin out at the same time and it'll pop out...simple as that....when i put my smoked cobras in i thought it was gonna be more difficult than that but it was real easy...good luck
Old Sep 10, 2007 | 10:20 PM
94Blk5.0's Avatar
94Blk5.0
To remove the yellow- try polishing compund. Apply, remove, repeat for about 10min per light or until satisfied.
To remove the water: drill a small hole near the bottom corner.
Don't remove them unless you plan on replacing them. I put new ones in mine it looked a whole lot better.
StalkerGT
Nov 28, 2015 03:09 PM
Seanam
Oct 4, 2015 10:15 AM
Drastang
Sep 29, 2015 03:31 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
amandahchase
Sep 3, 2015 10:09 AM
