VIBRATION CAN'T SOLVE.. HELP!
Old Sep 11, 2007 | 11:46 AM
autobody@sbcglobal.n's Avatar
Default VIBRATION CAN'T SOLVE.. HELP!
VIBRATION IN ALL GEARS 3500- 4000. SHIFTER SHAKING, AND D.SHAFT CAN ALSO BE SEEN SHAKING. PUSH DOWN CLUTCH PEDAL AND IT GETS WORSE. NEW HARMONIC BAL, TRANS/ENGINE MOUNTS, CHECKED PINION ANGLES,NEW U.JOINTS,BALANCED D.SHAFT AND SWITCHED WITH A FRIEND. VIB IS STILL THERE. WHAT NEXT?
Old Sep 12, 2007 | 08:06 AM
DesertMach's Avatar
DesertMach
Default RE: VIBRATION CAN'T SOLVE.. HELP!
Just a shot in the dark here, but maybe something in the clutch?? friction disc out of balance, flywheel, pressure plate?
Old Sep 12, 2007 | 08:26 AM
aode08's Avatar
aode08
ORIGINAL: autobody@sbcglobal.n
your flywheel may need turning, sounds like its warped or bad[:'(]
Old Sep 12, 2007 | 11:10 AM
ok, i'll replace clutch, pressure plate,fly wheel. but, with these parts being bad , would it transmitt the vib down shaft? so bad that i can see the d.shaft shake like crazy at the output shaft?
Old Sep 15, 2007 | 01:41 AM
onegreedy's Avatar
onegreedy
could be bad bearing in trans
mtgldr
Feb 3, 2024 09:00 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
mdj89
Sep 23, 2015 08:49 AM
ccdguy
Sep 19, 2015 05:20 PM
