99 HID headlights not working
Old Sep 19, 2007 | 06:44 AM
SmokeGT's Avatar
SmokeGT
Default 99 HID headlights not working
Hi, I have a 99 mustang GT. I recently installed HID lights with the ballast, and have the Halo headlights.
The lights have worked for about 4 months while the car was parked in my driveway. I was adjusting the lights a few days ago and one of the lights went out. I tested the brokenheadlight, and ballast on the working side and everything was fine, no problems with the light or ballast. I then tested the voltage coming out of the headlight plug and didnt get any voltage. Both high beams and signal lights are working, but no low beams on drivers side. I hooked up a jumper from the passenger headlight low beam wire to the drivers side low beam wire. When I did this and turned on the lights both stoped working. I tested the passenger side low beam at the headlight plug and now i have no power on that side either.
I have the Hanes manual and the wiring diagram in the book is not the same as my car. If anyone knows where I can find a wiring diagram, or help me with a possible solution to this problem it would be greatly appreciated. Thanks
Pyrate Dave
Sep 10, 2015 07:30 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
cbird1177711
Sep 3, 2015 08:43 PM
amandahchase
Sep 3, 2015 10:09 AM
