Engine codes?
Old Feb 20, 2005 | 11:35 PM
94droptop's Avatar
94droptop
Default Engine codes?
My check engine light is on? Is there any auto parts store that will run the codes for me or is there a way i can do it? does anyone know a product or technique to remove surface scratches? would this ebayunderdrive pulley work for my 94 lx vert( how big of a hp increase and how hard is it to put in?
Old Feb 20, 2005 | 11:38 PM
AtlanticBlue99's Avatar
AtlanticBlue99
I ♥ Acer
Default RE: Engine codes?
autozone for the codes, meguires 3-step for small scratches, depending on size of u/d pullry reduction determines hp increases.
Old Feb 20, 2005 | 11:41 PM
94droptop's Avatar
94droptop
howmuch will it cost to run the code?
Old Feb 20, 2005 | 11:52 PM
SShadowSSin's Avatar
SShadowSSin
FREE @ Autozone.
Old Feb 21, 2005 | 12:05 AM
94droptop's Avatar
94droptop
awwww !!!!!!! i paid 40$ at a shop once for that? would they be able to checka air bag light i was told it was a different computer
Old Feb 21, 2005 | 12:27 AM
luckythirteen13's Avatar
luckythirteen13
i went to one autozone and because i have a '92 and no obd2 port, the refused to do it. is that the commen rule or were they just d*cks?
Old Feb 21, 2005 | 01:58 AM
GTron's Avatar
GTron
ORIGINAL: luckythirteen13
You can check your own with the 92. Not 100% sure about the 94 though. I don't have the exact steps to do, but you just need a jumper wire and a test light. Do a search and I'm sure you can find it.
Old Feb 21, 2005 | 02:38 AM
bobby's Avatar
bobby
u mihgt notice a LITTLE hp improvement
Old Feb 22, 2005 | 10:36 AM
Djs94stang's Avatar
Djs94stang
Behind the right shock tower, toward the firewall, there is a plug with a cap marked EEC test on it. There is a large plug and a small one attached inside the cap. All you need to do is to jump a paper clip from one of the terminals on the large plug to the smaller one. The exact terminals are shown in my Haynes which I don't have with me. Then all you do is turn the key on and watch the engine light...it will blink the codes out.
Old Feb 22, 2005 | 11:15 AM
jdaniel's Avatar
jdaniel
I ♥ Acer
Here where I live, it costs $80.00 for any repair shop to pull the code. I have my own OBD II sensor and its paid for itself over and over.
