see through radiator hose?
hi, anyone know where to get some clear or see through radiator hoses, i wanna use em to check for air pokets and see how the flow is. also looks cool
, also ones that can withstand the high heat.
lol yea i know. i just want to see how it is flowing. i think i found a set for lower and upper hose for like 80$... not tryin to pay that much. i also want to install a radiator tube filter on there too. my cooling system is acting funny so i wanna see how it is flowing and see wat kind of things the filter catches.
Think about it.
You change your Coolant once a year tops.
And I have never seen anything in my coolant system that would warrant a filter.
And what about when the system gets clogged.
Water is more important than oil.
Starve an engine for oil, you get some ticking, add oil you normally save the engine.
Over heat one with no coolant......by-bye heads.
bye-byeblock, warpong crank wow total devastation.
I had a 69 SS Camaro, flushed the system and all was well......no need for filter.
Just a thought
But the clear hoses......SICK.
I would buy them if they were reasonable, but only tottally clear.
Silicone maybe.....silicone oven mits stand up to 450degrees.
A thought.
Just a thought
A thought.
http://neptune.spacebears.com/cars/stories/sctefba.html
how to make the filter imma make it this weekend. yea it has a second bypass incase of a clog so hopefully it doesn;t get clogged.
