fuel pump noise
Old Feb 26, 2005 | 11:42 AM
earthman32's Avatar
earthman32
Default fuel pump noise
I've got a knock that is loudest at low rpm ('66 coupe, 302 2 valve). I've replaced the lifters, checked the tension on the rocker arms, and the rods are straight. My only conclusion is that the mechanical fuel pump is worn (the car has been sitting for four years). BUt before I go and start pulling parts I wanted to know if this is the right answer. Any opinions/suggestions are welcomed.
Old Feb 26, 2005 | 05:21 PM
horseshoeing's Avatar
horseshoeing
Default RE: fuel pump noise
Is that where the noise is coming from? If it is, I would say that is is a good place to start. Its hard to say when I am not there.
Old Feb 27, 2005 | 07:29 AM
mikev08826's Avatar
mikev08826
I ♥ Acer
That kind of vibration/sound/knock would be unusual from the fuel pump i think.
Old Feb 27, 2005 | 01:12 PM
vfast's Avatar
vfast
I ♥ Acer
no it's possible...it could have the wrong F/P rod..and it's cheap to try so buy a new pump and a new rod from mr. gasket..also do you have power streering?
Old Feb 27, 2005 | 02:28 PM
earthman32's Avatar
earthman32
The knock is coming from the front of the engine, on top.
The car does not have power steering.
The knock sounds like a collapsed lifter, but I replaced them and it didn't remedy the noise.
Old Feb 27, 2005 | 08:03 PM
Ohoneandahalf's Avatar
Ohoneandahalf
Check your pushrods?
Oct 26, 2015 05:01 PM
Meystang
Sep 25, 2015 04:05 PM
pimp2303
Sep 17, 2015 08:45 PM
SteelerNation82
Sep 16, 2015 07:11 AM
rksnow1
Sep 14, 2015 08:46 PM
