carb problems!
Old Oct 29, 2007 | 04:35 AM
Gary H's Avatar
Gary H
Default RE: carb problems!
Make sure the fuel lines are connected right. You might pull the fuel line and have someone crank it over while you put a finger over the end of the line. You should feel air pressure pushing against your finger.
How to rebuild the carb
http://home.earthlink.net/~bubbaf250...rb/carb03.html
Old Oct 29, 2007 | 10:30 PM
Colorado_Mustang's Avatar
Colorado_Mustang
It'd be safer to put the fuel line into a container that can hold the gas so you can see if there's gas flowing. Putting your finger over the end of the line with gas and pressure will cause it to squirt all over, and can get into your eyes or airways...neither of which are really things you want.
ORIGINAL: Gary H
Old Oct 30, 2007 | 04:37 PM
ddupont's Avatar
ddupont
yes gas is def getting up past the pump and through the filter... i kno this cuz i took the top off and cranked the engine to see n gas came shooting up in the air!!! im not sure wat that means but at least i kno its not the pump or filter!!!
Old Oct 30, 2007 | 05:32 PM
67mustang302's Avatar
67mustang302
Something's jammed up in the carb then, piece of trash, broken parts etc
Old Oct 31, 2007 | 12:38 AM
johnnyhou's Avatar
johnnyhou
I often use a bread tie, (twistie tie) after using a lighter to burn off the paper/plastic, you are left with a thin wire. Disassemble the carb and use the wire to free the passages in your jets, pump sprayers, VENT HOLES (in the body itself) and any other orifices that are necessary to provide proper carburetion. Use a can of carb cleaner to make sure the passages are clean by spraying through each passage to ensure fluid flows freely. You don't necessarily have to put the tie all the way through the passage in most cases as the blockage is at the orifice. Make sure all orifices are fully open, but DO NOT USE ANYTHING OR DO ANYTHING THAT MAY OPEN THEM UP MORE THAN THE ORIGINAL SIZE HOLE!
Old Oct 31, 2007 | 01:01 PM
ddupont's Avatar
ddupont
i ran it with the top off n the only way i can keep it running is if i keep adding gas to the chamber where the floats are... and i know that gas is getting past the pump cuz i put the hose in a soda bottle and cranked the engine and gas is filling up the bottle...the filter is brand new... im pretty sure the floats are set right but not possitive... wats left??!! acc pump? thats new also... any ideas?
Old Oct 31, 2007 | 06:28 PM
ddupont's Avatar
ddupont
clean jets... a few replaced rubber hoses... reset foats...runs like a champ... thnx a million guys!
uberstang1
Sep 20, 2015 06:42 PM
Sminemann
Sep 17, 2015 09:24 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
jaiidutch
Sep 14, 2015 10:29 AM
tramphardrocker
Sep 13, 2015 08:56 PM
