carb problems!
Old Oct 28, 2007 | 04:03 PM
ddupont's Avatar
ddupont
Default carb problems!
hey guys...
i have a 76 5.0 mustang 2 that im trying to get up and running b4 winter and am having problems with i think the carb. when i turn the key the engine cranks but doesnt turn over. when i dump a lil gas in the carb, it starts up like a champ but dies after a lil while... i got a rebuild kit, changed the excelerator pump and i put in a new fuel pump so i know gas is def getting to the front chamber of the carb (where the floats are) i think i set the floats right, and blew out the jets so i dont think nething is clogged... idont know 2 much about carbs so any help will be appreciated...
thnx
Old Oct 28, 2007 | 05:14 PM
67mustang302's Avatar
67mustang302
Default RE: carb problems!
What carb is it? If it starts when you pour gas into the carb, but won't stay running, or won't start on just the carb, then you still have a carb problem
Old Oct 28, 2007 | 05:38 PM
Gary H's Avatar
Gary H
Check the filter. After it dies, look in the carb and move the throttle and see if gas is squirting into from the acc pump.
Old Oct 28, 2007 | 05:41 PM
ddupont's Avatar
ddupont
i believe it has a motorcraft Model (9510). it looks like it has been rebuilt recently(i only purchased it earlier this year) i dont know anything about carbs so i am in the dark about what it can be...
Old Oct 28, 2007 | 06:02 PM
67mustang302
Did you change the filter? I'm assuming you did when you changed the pump, correct?
Old Oct 28, 2007 | 06:06 PM
ddupont's Avatar
ddupont
new fuel filter + pump...floats are wet but doesnt look like gas is getting anywhere from there... after cranking the motor, if i open the choke plates, it def looks dry...put in new acc pump but other then that i dont kno wat to do!
Old Oct 28, 2007 | 06:12 PM
67mustang302
Do what Gary said, look in the barrel and open the throttle and see if any fuel is spraying from the pump
Old Oct 28, 2007 | 06:16 PM
ddupont's Avatar
ddupont
there def isnt anything spraying...its dry as a bone... so wat does that mean?? jets r clogged? my new acc pump is trash??
Old Oct 28, 2007 | 06:34 PM
67mustang302
Well, if it starts if you pour fuel in it, but dies out, and there's no fuel from the accelerator pump, then either your floats are set wrong, or something else is keeping you from getting fuel through the carb/accelerator pump
Old Oct 29, 2007 | 01:16 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Sounds like the carb just needs cleaned out. Is there fuel in the bowl (take the top off to look...and the Ford carb can run without the top, just make sure the needle/seat have the splash guard installed).
