No heat
Old Oct 29, 2007 | 07:31 PM
stumpfoot's Avatar
stumpfoot
Default No heat
I have no hot air coming from the vents in my 90 mustang. Any thoughts? I live in Central Oregon and this car will be undrivable without heat or defrost.
Old Oct 29, 2007 | 07:45 PM
GreyStang's Avatar
GreyStang
Default RE: No heat
Does the heat/cold dial on the dash feel like it's attached to anything? Maybe that cable has busted
Old Oct 29, 2007 | 07:50 PM
golden_eye's Avatar
golden_eye
Default RE: No heat
Check your coolant also. I found that if my coolant was low there wouldn't be enough to fill the heater core and it would blow lukewarm air at best. It is most likely the cable though.
Old Oct 29, 2007 | 07:57 PM
stumpfoot's Avatar
stumpfoot
Default RE: No heat
Coolent is full and it feels as though the cable is connected and working as there is resistence when you turn the dial.
Old Oct 29, 2007 | 08:10 PM
351W THUNDER's Avatar
351W THUNDER
Default RE: No heat
can u feel a little of heat coming out? happened to mine, the heater motor just froze and needed to be freed up
Old Oct 30, 2007 | 12:02 AM
stumpfoot's Avatar
stumpfoot
Default RE: No heat
I suppose it is slightly warmer then outside. Is there a "schematic" for the heat system? At least that way I can check one thing at a time until I get it going.
Old Oct 30, 2007 | 10:39 AM
marioso28's Avatar
marioso28
Default RE: No heat
My 88 is doing the same. The AC blows very cold but the heat is not so hot. Not sure why.
Old Oct 30, 2007 | 03:52 PM
xz06's Avatar
xz06
Default RE: No heat
could be a faulty thermostat,keeping your motor from reaching operating temperature.Do you have a temperature gauge in your car?If it's not in the operating range,change the the thermostat.
Old Oct 30, 2007 | 05:31 PM
stumpfoot's Avatar
stumpfoot
Default RE: No heat
ctually the previous owner took it out, the heater didnt work then. I just put a new one in and it didnt make any difference.
Old Oct 30, 2007 | 06:59 PM
1991LX5.0's Avatar
1991LX5.0
Default RE: No heat
try burping the system, usually if you get an air pocket in the system one of the first signs is no heat. Also is the car getting up to rormal operating temp?
