window wont roll up.....help
Old Nov 4, 2007 | 08:19 PM
SALEEN_TIME's Avatar
SALEEN_TIME
Default window wont roll up.....help
How do you know if its your motor in the window or the switch that is the problem? Its an 02' and the driver side window wont roll up, there is no noises being made when the up button is pushed. What do you guys think and is it easy to fix?
Old Nov 5, 2007 | 04:29 AM
NJcobraEkul's Avatar
NJcobraEkul
Default RE: window wont roll up.....help
take off the door panniel disconnect the power from the window motor. hook up a test light if it lights up then motor it is or disconnect power from the motor run a wire from the battery power (red) to the motor see if that works make sure the motor is grounded. let me know
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
flash_xx
Oct 16, 2015 07:23 AM
Explosive
Oct 2, 2015 07:45 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
