'89 5.0 fuel pump problem
Old Nov 8, 2007 | 06:02 PM
jtee's Avatar
jtee
Default '89 5.0 fuel pump problem
Have replaced pump and the relay under drivers seat. have power to reset button in hatch, but no power in connection going to pump. wiring seems ok
Old Nov 9, 2007 | 05:46 AM
corvetteguy's Avatar
corvetteguy
Default RE: '89 5.0 fuel pump problem
Check the 12 volts on the main lead
of the fuel pump relay.
There is a fuse link off the main 12 volts that feeds
directly to the relay.
If you bypass the relay main terminals the new pump
should run.
The computer normally tells the relay to
shut down if the motor is not running.
Old Nov 9, 2007 | 07:26 PM
jtee's Avatar
jtee
Was able to to get fuel pump to run. Is this permanent or is there something in the computer to deal with ?
Design1795
Jan 24, 2017 10:38 PM
YoungStangsMan
Sep 5, 2015 07:01 PM
Design1795
Aug 24, 2015 04:41 PM
labudski
Aug 24, 2015 07:23 AM
drumhedd2005
Aug 13, 2015 09:59 AM
