redline
Old Mar 3, 2005 | 03:21 PM
ryanz's Avatar
ryanz
Default redline
Does anyone know what the rev limiter is on a manual 01 GT? I was also wondering if the rev limiter rpm is the same as the redline rpm?
Old Mar 3, 2005 | 04:06 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: redline
ORIGINAL: ryanz
Any reason why you posted this twice? Anyways,
Q1) Don't have a GT so can't help ya there
Q2) No, they are not the same. Redlining just means you are hitting what's considered the 'top-end' of what the computers consider 'safe' for the motor. The rev limiter keeps you from reving the engine past a certain point. At idle in nuetral, hit the gas...at around 3500-4000 rpm the motor will start to miss and keep your Tach bouncing around a specific RPM that's your rev limiter kicking in. If you put it in gear and floor it, you'll go past redline and at some point the gas will cut off to your engine. That too is a rev limiter.
Some cars have their rev-limit set at redline, some have it set elesewhere, and some have none because someone reprogrammed the computer to turn off the limiters.
Old Mar 3, 2005 | 07:15 PM
Ohoneandahalf's Avatar
Ohoneandahalf
Default RE: redline
The answer is redline is at 5800 and the rev limiter bounces at 6100 or 6200.
Old Mar 3, 2005 | 08:43 PM
Guest
Guest
Posts: n/a
Default RE: redline
my redline is 8000 rpm, fuel cutout is 8200 rpm. [8D]
I hit it last sunday... it feels like you just nailed a brick wall.
Old Mar 3, 2005 | 09:18 PM
pipeliner's Avatar
pipeliner
Default RE: redline
ORIGINAL: 2000Si
Damn hondas
JoshyGT
Sep 19, 2017 08:52 PM
imported_admin
12
Dec 16, 2004 07:43 AM
dhood
Mar 16, 2004 05:20 PM
