mounting battery in trunk
Old Mar 8, 2005 | 01:11 AM
dc_mann8's Avatar
dc_mann8
Default mounting battery in trunk
got a plastic battery box (swiped it off a trailer at the local RV sales place..) gonna pick up some 0 positive cable tomorrow, how many feet should i need? and where do i ground to? is there somewhere in the hatch good for that? what size ground cable do i need? i dont need a shut off switch for where i am racing at so thats ok, but how do i vent it? i dont understand, and where do i put my two 3/8 hold downs?
Old Mar 8, 2005 | 03:11 AM
luckythirteen13's Avatar
luckythirteen13
Default RE: mounting battery in trunk
if the box isnt air tight, it will just vent all over your car. if it is, the vent tube should be run outside.
you will also want a 0 gauge ground to anything metal in the trunk or you can run it back to the block.
Old Mar 8, 2005 | 08:11 PM
dc_mann8's Avatar
dc_mann8
how do i hold down the battery box? and is there any holes in the bottom of my hatch to run the vent?
Old Mar 8, 2005 | 09:47 PM
dc_mann8's Avatar
dc_mann8
the box is not air tight, is it ok to vent all over my car.... or is that bad for me lol
Old Mar 8, 2005 | 11:48 PM
luckythirteen13
i think its ok but dont hold me to it. most of the time i drive with my windows down so it wouldnt matter there. to be nhra legal it has to be air tight though. i doubt there are any holes in the hatch for the 3/8" tie down bolts or the vent so youll have to drill them
Old Mar 9, 2005 | 12:11 AM
dc_mann8's Avatar
dc_mann8
mine are usually down too... but... if they are up when parked over nights and ****.. will this hurt me? i can porbably make it air tight and vent it.. but i dont want to do the work if this wont bother me
Old Mar 9, 2005 | 04:40 AM
luckythirteen13
personally i wouldnt worry about any fumes. its a battery..... as long as you keep corrotion (sp?) off the terminals you should be fine. if your worried get a high quallity batter like optima. if you want, your could put the battery in a plastic bag
Old Mar 9, 2005 | 11:04 AM
dc_mann8's Avatar
dc_mann8
yeah i think ill get an optima
Old Mar 11, 2005 | 01:10 AM
brando5.0's Avatar
brando5.0
If you are using at a NHRA track, the only company that I know of that makes a plastic, NHRA approved box is moroso. Otherwise, you might have to use an aluminum or steel box. As far as what to connect the wires to, I would run 2 sets and solder them into the stock battery cable ends. That way, you will know that you are getting the power where you need it, and where it was originally intended. When you drill the holes for the hold down, be carefull, the gas tank is pretty close to the underside of hatch, especially towards the rear. Good Luck!
Old Mar 11, 2005 | 01:15 AM
C/Note's Avatar
C/Note
I ♥ Acer
i just did mine in 00 i got 18 ft will do pos and short neg with 2 ft left over,,,
