Clutch Feel
Old Nov 24, 2007 | 09:36 PM
ftBrz's Avatar
ftBrz
Default Clutch Feel
Hey guys,
What would I have to do/have done by someone else to shorten the clutch range of motion and soften it?
- -Steve
Old Nov 29, 2007 | 08:58 PM
Jfsram's Avatar
Jfsram
Default RE: Clutch Feel
Shorten will do the opposite and make it harder.
Start with cheap and easy fixes. Lube the clutch cable or replace it.
If you still want it softer. It most likely is a high performance pressure plate. Replace it with a stocker or a Centerforce I.
Old Dec 5, 2007 | 05:54 PM
TheDrivenMan's Avatar
TheDrivenMan
If your actuator is working correctly, that is, the cable is free and working ok, and the pivot stud is not worn out, then the culprit is usually a cheap pressure plate and clutch combo.
There are two ways to make a clutch handle power.
1. Put a great friction surface together with a low spring rate pressure plate.
2. Put a cheap friction surface together with an enormous clamp load.
Essentially, if you don't have friction on your side, the pressure plate has to have a spring pressure rate that will clamp the heck out of the disc. Your leg has to overcome that spring when you release the clutch resulting in hard pedal effort.
A number of companies, including SACHS, ZOOM and CenterForce have products that combine advanced friction materials with lower spring rates in the pressure plate to deliver killer performance without blowing the ligaments out of your legs.
Check your linkage and if it is OK then look at a better clutch choice.
Thunderball
15
Nov 22, 2015 11:49 PM
guitarman376
Sep 30, 2015 05:54 PM
junior04
Sep 28, 2015 10:53 AM
GLOCKer
Sep 28, 2015 07:36 AM
MacSerio
Sep 27, 2015 01:05 PM
