Car won start...bad starter ?
Old Dec 10, 2007 | 08:54 AM
jlbmcg1015's Avatar
jlbmcg1015
Default Car won start...bad starter ?
Hey guys. I'm having issues with my Stang. I've checked the battery and alternator and they are perfect. Maybe once a week, my car won't start. It doesnt turn over and no lights (outside/interior) dont turn on, not even the stereo turns on. It'll start once I get a jump. One time, I didnt have anyone to jumpstart me, so what I did, was connect the + and - on my battery, took the other ends and touched them together to make sure they sparked. I did that, they sparked, and suddenly my lights inside turned on (door was ajar) so I fired up the Stang and it started. Could it be a bad starter ?
Old Dec 10, 2007 | 11:12 AM
GreyStang's Avatar
GreyStang
Default RE: Car won start...bad starter ?
No it's not a bad starter if the lights aren't working either.
It could be something like corroded battery cables, or a thermal fuse popping. But I'm not aware of a thermal fuse that would affect the starting and lights/radio. am not sure.
But I wouldn't blame the starter. If you did that you might as well replace the headlights too if they quit working intermittently lol
Old Dec 10, 2007 | 11:22 AM
Chopper's Avatar
Chopper
Try cleaning the battery terminals,inside and out.
Check for a bad ground.You can do this by using a jumper cable connected to the negative battery terminal and connecting the other end to a ground on the engine.This isn't a 100% positive test but if the starter and other electricals start working when the jumper is hooked up you know what to look for.
Old Dec 10, 2007 | 11:27 AM
jlbmcg1015's Avatar
jlbmcg1015
There was a "fast" clicking noise coming from underneath the console/dash on the driver side too. Don't know if that helps. I did clean the terminals and inspected the cables. I looked over all the fuses and they seemed okay.
Old Dec 10, 2007 | 02:07 PM
Civic_Top_Gear5's Avatar
Civic_Top_Gear5
I ♥ Acer
it could be an electrical problem within the car
Old Dec 10, 2007 | 05:16 PM
99_GT's Avatar
99_GT
What is the battery voltage???
Old Dec 11, 2007 | 09:36 AM
jlbmcg1015's Avatar
jlbmcg1015
battery voltage was at 13.75 and amps started at -1 then started going lower to -3
Old Dec 11, 2007 | 04:56 PM
jlbmcg1015's Avatar
jlbmcg1015
BUMP
Old Dec 11, 2007 | 05:38 PM
99_GT's Avatar
99_GT
That battery voltage is too high. It probubly fried somthing. It should be around 12.5 +/- . 13.75 is HOT...
Old Dec 12, 2007 | 09:09 AM
jlbmcg1015's Avatar
jlbmcg1015
ORIGINAL: 99_GT
So what do you think it might be?
chain
Aug 17, 2015 08:52 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
Itstbrown
Aug 9, 2015 03:49 AM
