4.6 SOHC or DOHC
ORIGINAL: STANG0446
how do i know if my 04 gt has pi heads or waas it standard?
you already have PI everyhting, so dont buy a PI intake, especially on the 04 since you already have the aluminum crossover. the typhoon is just an all aluminum aftermarket intake. not worth all the money IMO unless your doing alot of work
ORIGINAL: allg32
so I would assume the 96 GT had the DOHC. Also have seen some comments about 2V or 4V whats the difference. 2 valves vs 4 valves per cylinder?
I would have to say that the SOHC 4.6 is one of the uglies engine ford ever built. I was going to put one of them in my ******. But unless you cover the engine completely it is ugly. That is why I went with the DOHC 4.6. Now I just have to get done with my daughters car so I can get the ****** back in the shop to start putting the twin turbos on it.
http://i259.photobucket.com/albums/h...r/DSCN0023.jpg
ORIGINAL: tbirdscwd
rule of thumb: from 99-2004 the gt (incl bullitt) came with a 4.6l sohc 2v per cyl, and cobras (and Mach 1s) came with 4.6l dohc 4v per cyl. 2005+ mustangs have 4.6l sohc 3v per cyl.
ORIGINAL: allg32
May 9, 2024 05:51 AM
