Oil Pressure gone!
Old Jan 18, 2008 | 03:18 PM
RJRRRRR5's Avatar
RJRRRRR5
Default Oil Pressure gone!
I'm new, so any help is appreciated.
I HAVE A 2001 gt with a lot of freeway miles and recently I began hearing the famous "ticking" that I have heard is the Timing belt tensioner. The funny thing is that it runs great and had just easily passed CA smog. Driving home the oil pressure went to zero and the ticking got worse. I shut it down and restarted and the pressure went back to normal and the ticking returned to the original noise level. I'm not driving it currently, but have started it often to keep the battery going. Yesterday, the pressure went to zero and the pressure is gone for good this time.
Questions- Can I get to the oil pump through the pan or do I have to go through the timing chain cover? Could the timing chain tensioner caused the oil pump to go? Are they related?
The car runs great and doesn't miss, so my hope is that it is "just" the oil pump.
Thanks in advance!
RJRRRRR5
Old Jan 18, 2008 | 07:01 PM
Chopper's Avatar
Chopper
Default RE: Oil Pressure gone!
You need to hook up a known-good oil pressure guageand get an accurate reading and repost.
The ticking sound you hear could be the cam chain tensioner but it's really not a ticking sound it's more of a heavy clatter.
http://www.bullittarchive.com/7019.htm
The above link is a description of the noises andwhere theycould be coming from.
Give it a read and repost.
Old Jan 20, 2008 | 12:21 AM
pete1665's Avatar
pete1665
fyi you DO neet to remove the timing cover & chains/sprocket to get at the oil pump. might as well replace the tensioners/guides while your in there.
svfetter
Oct 5, 2015 11:39 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
wraith777
Sep 28, 2015 10:49 AM
ccdguy
Sep 19, 2015 05:20 PM
SteelerNation82
Sep 16, 2015 07:11 AM
