retarted wipers
Old Jan 13, 2008 | 08:55 AM
Narleycarley's Avatar
Narleycarley
Default retarted wipers
what would cause my wipers to stay on ALL THE TIME its a 95 mustang
Old Jan 13, 2008 | 10:07 AM
Phantoms's Avatar
Phantoms
Default RE: retarted wipers
Could be the switch or the fuse.
Old Jan 13, 2008 | 10:23 AM
Narleycarley
well... tried new wiper/turn signal lever switch, and same thing. I tried a junkyard wiper motor (since that has the wiper control module bolted on it) and no different. what else controls these wipers?
Old Jan 13, 2008 | 10:30 AM
Phantoms's Avatar
Phantoms
did you try the relay or fuse?. I had a problem with my heater doing the same damn thing. turned out to be a fuse had gone bad.
Old Jan 13, 2008 | 10:33 AM
Narleycarley
ya, if i pull the fuse it turns off. which relay is wipers? (i dont have an owners manual so i'm flying blind also) [:@]
Old Jan 13, 2008 | 10:46 AM
Phantoms's Avatar
Phantoms
If wipers wont shut off unless ignition is off......
disconnect the wiring from the wiper control swtich. If the wipers stop, replace the switch. If the wipers keep running, there's a defective limit switch in the motor, replace the motor.
Haynes Ford Mustang 1994 thru 2004 Repair Manual
I don't know if this is the same on the 95, but for my 97 the fuse for the wipers is in the instrument panel, location #2, on the bottom row second from the right.
Old Jan 13, 2008 | 04:53 PM
Narleycarley
ok... if new motor dont fix it, that repair manual say anything else?
ya, the 95 fuse is the same as the 97
it keeps running with the switch bein pulled, but new motor didnt change anything GRR!!
Old Jan 14, 2008 | 01:02 AM
Cryptostorm's Avatar
Cryptostorm
the fuse wouldn't have anything to do with this problem....
i haven't had this problem... but its probably the relay....
if you haven't figured it out by tomorrow, ill pop out my schematic and check it out..
Old Jan 17, 2008 | 08:03 PM
Narleycarley
Wiper module, $180 Dealer only item, its under the dash by the fuse panel, but thats what the deal was. thank ya'll
jma2
Jul 10, 2023 01:00 AM
PNYXPRESS
Sep 14, 2015 09:50 PM
Hogquad
Aug 23, 2015 05:26 AM
jlopez07
Aug 21, 2015 09:28 AM
Autogeek
Mar 10, 2009 07:09 AM
