egr problem
Old Mar 25, 2005 | 11:03 AM
smokinv6's Avatar
smokinv6
Default egr problem
my check engine light came on and it was my egr system...i replaced the egr valve n then the light still came back on. do u think it is the solenoid or switch..wut do yall think
Old Mar 25, 2005 | 01:21 PM
luckythirteen13's Avatar
luckythirteen13
Default RE: egr problem
did you reset the computer? disconnect the batter for 10min +
Old Mar 25, 2005 | 02:08 PM
96SilverLT1's Avatar
96SilverLT1
Exactly. you have to be sure that the PCM is reset.
Without knowing exectly what motor you have I can only share some of my other expriences with other ford issues. number one what code are you getting. P0401? The 4.6/5.4L trucks are REALLY bad about setting this code due to cloged EGR passageways into the intake preventing flow of the exhaust gas. On platic intakes this generaly doesn't happen. Another think is if you have a DPFE sensor. (small box with an electrical connetor and 2 hoses running from it to the EGR tube) They are really bad about failing and setting this code. Make sure that the hoses are not borken or have fallin off. Only way to test the sensor is with a meter but I don't know which if the 3 wires is the signal wire off hand other wise I could tell you what to test
Old Mar 26, 2005 | 01:00 AM
smokinv6's Avatar
smokinv6
i have a 2001 v6 mustang and i did reset the light and it came back on the next day
Old Mar 26, 2005 | 02:09 AM
Casper98GT's Avatar
Casper98GT
I ♥ Acer
Easy fix. Replace the DPFE. lol. Remove it and tap it on something hard, water will come out of it. Fords number one problem, they set it up wrong ( sensor ) so it collects water from the exhaust, and it gets trapped in there.
Old Mar 28, 2005 | 08:51 PM
smokinv6's Avatar
smokinv6
where is this sensor (DPFE) located at?? what does it look like?
Old Mar 28, 2005 | 11:43 PM
96SilverLT1
I already described it. It's usualy mounted on teh intake. small box with an electrical connetor and 2 hoses running from it to the EGR tube. Just look for the EGR tube and follow the rubber hoses. thats your DPFE sensor
Old Mar 28, 2005 | 11:53 PM
smokinv6's Avatar
smokinv6
did it...no water so what is next guess
Old Mar 29, 2005 | 12:19 AM
96SilverLT1
That doesn't mean that it's not bad... only way to know is to have a scan. If the tech knows what to look for they should be able to know if it's bad. usualy the voltage sticks high.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
TfcCDR
Sep 14, 2015 12:08 PM
