Backfirining Problem
Old Mar 25, 2005 | 05:06 PM
94stangcobra18's Avatar
94stangcobra18
Default Backfirining Problem
I just got my new clutch put in and thought it was the problem and would fix it but when i push in on the gas it wants to die on me and starts backfiring. Wondering what the problem was thankls
Old Mar 25, 2005 | 06:35 PM
Djs94stang's Avatar
Djs94stang
Default RE: Backfirining Problem
I would start with the TPS. Check a manual like Haynes or better. They have a procedure for checking it. I think you measure 0.5 at idle and up to .99 ohms or volts (can't remember which) at full throttle. Someone else here with manual handy or a good memory will probably respond with the correct figures. The mechanical culprits could be ignition or cam timing...also check the fuel pressure. You can check it initially by just turning the key to the on position with gauge hooked up on the fuel rail at the schrader valve. Good luck.
Old Mar 29, 2005 | 12:28 AM
Aongus's Avatar
Aongus
Another simple thing to check is for fouled plugs.
Old Mar 29, 2005 | 12:30 AM
dc_mann8's Avatar
dc_mann8
check easy things first.. replace cap wires plugs etc
69Volunteer
Sep 30, 2015 10:39 AM
marc954
Sep 29, 2015 03:05 PM
marc954
Sep 25, 2015 06:48 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
