1966 Engine
Old Jan 22, 2008 | 11:08 AM
aggies90's Avatar
aggies90
Default 1966 Engine
Hello I HAVE a 1966 Fastback 289 with a/c and power brakes......If I want to install a crate engine is there a size I can not use?????? 302???351???? thanks if anyone can help or any sugestions on where to get a good crate.....
Old Jan 22, 2008 | 11:13 AM
bacon57's Avatar
bacon57
Default RE: 1966 Engine
You can use the 289/302/351 engines, they are basicly the same but I don't think you can use the FE engines 360/390/427 or the big block 429/460 without serious modifications
Old Jan 22, 2008 | 12:10 PM
aggies90's Avatar
aggies90
Thank you....which would you place for a good street car every day driver with good pop...302or351
Old Jan 23, 2008 | 05:40 PM
mustangmatt63's Avatar
mustangmatt63
You can drop a 351 in there no problem!With a big Block you would need serious mods as in cutting out the shock towers,etc,etc!You will get a lot more power out of a 351!You can get them at a lot of different places with lots of different setups it depends on what you want!Good Luck with it![8D]
[IMG]local://upfiles/72436/FE6ED5B4E0A64B9A85A8361030FB4DE9.jpg[/IMG]
[IMG]local://upfiles/72436/9A259983349E4A01846A9D8D4791AD3B.jpg[/IMG]
Old Jan 24, 2008 | 07:25 AM
aggies90's Avatar
aggies90
Thank u for the info.......would I have to make alot of change to the exhaust....I do have y headers now....any thoughts on the 302 boss????
Old Jan 24, 2008 | 07:57 AM
mustangmatt63
BOSS 302 is a Great motor!! A 289 and 302 are basically the same Block,different compression ratio,An original 69/70 Boss302 is Hard to Find.The difference in the Comp ratio from a reg 302 to a boss302 is 9.5/1 to 10.5/1.Whatever you decide as long as its a Small block Ford V8 you should have no problem with the exhaust!!
Nick Oliver
Oct 17, 2018 04:22 AM
GPR
Dec 16, 2015 12:21 PM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
