Speed density and MAF?
Old Jan 24, 2008 | 02:11 AM
thrty5thsc's Avatar
thrty5thsc
Default Speed density and MAF?
What is the difference?
Thanks
Old Jan 24, 2008 | 06:35 AM
Jugador's Avatar
Jugador
Default RE: Speed density and MAF?
MAF meters how much air is taken in, speed density guesses how much is taken in based on engine vacuum. speed density gets finnicky whenever you mod it a lot because it doesn't know exactly how much air is coming in
Old Jan 24, 2008 | 09:39 AM
Jfsram's Avatar
Jfsram
Stock to stock, SD is faster but hey, who is stock?
Old Jan 24, 2008 | 11:11 AM
GreyStang's Avatar
GreyStang
ORIGINAL: Jfsram
Is it?? If that's the case then why did Ford switch from SD to MAF back in '88?
Old Jan 24, 2008 | 04:01 PM
thrty5thsc's Avatar
thrty5thsc
Hmmm, So nitrous is out of the question then huh? What do I need to do to convert to MAF. I just picked up an 86 GT vert and I plan to do as many mods as I can afford.
Old Jan 25, 2008 | 06:31 PM
Jfsram's Avatar
Jfsram
ORIGINAL: GreyStang
ORIGINAL: Jfsram
The switch was nothing to do with power. They were better able to deal with tightening emissions with MAF. Power is almost the same. Wheel dyno's prove it. Most every Mustang out there dynoing 195-205hp PEAK. The SD cars seem to have an edge in power under the curve. The average torque is higher, peak the same.
This is just a theory and my belief also stems from the fact I've seen lots of 87-88's run 99-101mph. Most MAF cars are mid 90's.
jwog666
Dec 27, 2021 08:09 PM
UrS4
Oct 3, 2015 06:23 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
BeatnikFink
Oct 1, 2015 08:00 PM
musnicki
Sep 23, 2015 07:11 AM
