Engine Rattle
Old Mar 26, 2005 | 11:16 PM
V8M2000's Avatar
V8M2000
Default Engine Rattle
I have a 2000 gt and when i am accelerating and runing about 2700 rpm i can hear a rattle from what i think is the engine. Also there is a similar noice when at idle. I am trying to avoid taking it into the shop so any help would be great.
Old Mar 26, 2005 | 11:56 PM
vfast's Avatar
vfast
I ♥ Acer
Default RE: Engine Rattle
first throw in some 93 gas and see if ti goes away
Old Mar 27, 2005 | 02:19 AM
V8M2000's Avatar
V8M2000
Yeah i have been running premium but it still rattles
Old Mar 27, 2005 | 07:39 PM
Djs94stang's Avatar
Djs94stang
Try to rev the engine from under the hood so that you can be up close and personal with the engine compartment. The other thing you can try is to powerbrake the car if it is a auto or set the parking brake and drag the clutch to put some load on the engine while someone listens and see if you can identify it. Your first sentence would have most believe it is a ping (detonation) but when you mention that there is a similar noise at idle is sort of blows that theory unless they are two different problems. It could be a heat shield on the cat conv rattling.
Old Mar 28, 2005 | 10:16 AM
Texas 67's Avatar
Texas 67
If the rattle seems to be coming from under the car it is probably the converters. They are notorious for this. The best way is to bring the rpm up to just over idle sitting still and they usually will rattle there.
Old Mar 28, 2005 | 11:37 AM
stanglx2002's Avatar
stanglx2002
ORIGINAL: Texas 67
i would check that first because i had that problem before
Nick Oliver
Oct 17, 2018 04:22 AM
bjdutch2005
Mar 24, 2017 03:38 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
tmdm
Sep 4, 2015 06:45 PM
