1994 f150 brakes
Old Jan 31, 2008 | 11:37 AM
99BlackPonyGT's Avatar
99BlackPonyGT
aka 'Negative Nancy'
Default 1994 f150 brakes
my brakes on my winter beater are like...locked down sorta...if i put the truck in gear and let off the brake it just sits there for a few seconds then slowly starts to roll and as soon as i get on the brakes the pedal is half way down already and they just lock... then i let off and it will slowly start creeping again...anyone know the issue? fluid is full i already checked...i can go from park to reverse to drive without even touching the brake....
Old Jan 31, 2008 | 12:04 PM
AmericanMuscle4.6GT's Avatar
AmericanMuscle4.6GT
Default RE: 1994 f150 brakes
check your brake lines
Old Jan 31, 2008 | 12:09 PM
99BlackPonyGT
if the lines were bad/broken, wouldnt the pedal just drop to the floor though?
Old Jan 31, 2008 | 12:20 PM
AmericanMuscle4.6GT
ORIGINAL: 99BlackPonyGT
well your thinking if they're somehow ruptured, meaning a leak would take place, meaning you'd be finding brake fluid all over your driveway. so no, i don't think they're cracked or anything like that. but, maybe they're gummed up or something like that. sounds like they might actually be crimped somewhere, as the fluid doesn't seem to be flowing freely.
Old Jan 31, 2008 | 12:21 PM
99BlackPonyGT
thanks ill check that out, gonna look at my front rotor and caliper too it was damaged and never fixed...thinkin maybe i pushed it too far...
Old Jan 31, 2008 | 12:37 PM
SKAR's Avatar
SKAR
Super Moderator
check everything/ bump
Old Jan 31, 2008 | 01:46 PM
my77stang's Avatar
my77stang
master cylinder?
Old Jan 31, 2008 | 01:52 PM
ewgoetz's Avatar
ewgoetz
Make sure the calipers move freely. if it is siezed the brakes can cayse that.
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
