exhaust popping
Old Feb 4, 2008 | 07:19 PM
ryan1994mustang's Avatar
ryan1994mustang
Default exhaust popping
i have a 94 gt that is pretty much stock except for a k&n filter and flowmaster 40 series mufflers. sometimes when i try and accelerate, the car seems to lose power and studder and then a pop sound will come from the exhaust and my power will pick back up. it just seems like it is building up back pressure and losing power and then the pop releases it and i get my power back. anyone know what this could be? is it clogged cats or something?
Old Feb 5, 2008 | 08:41 AM
00blackstang's Avatar
00blackstang
Default RE: exhaust popping
back firing... it either gas ignighting in ur intake manifold or your exhaust... ur car is running either to rich or lean, i forgot which
Old Feb 5, 2008 | 09:54 AM
tylerl90's Avatar
tylerl90
Well the backfiring can be because you only have aftermarket mufflers. Get a catback and an aftermarket midpipe. That should eliminate popping.
Old Feb 5, 2008 | 11:25 AM
ryan1994mustang
well...i have had the same series mufflers on for as long as i have had the car (about 6 years) and i have never had any problems like this before, so im pretty sure its not the mufflers. but ill have to check into my A/F ratio. whats the easiest way to have this looked at? im assuming ill have to hook it up to a computer of some sort?
Old Feb 5, 2008 | 11:44 AM
koesterca1's Avatar
koesterca1
If it was just making popping sounds id say it could be the exhuast but since its also running bad theres something wrong with the way your cars mixing/burning the gas. Is it throwing any codes?you could pull a few plugs to see if your running rich/lean.
Old Feb 5, 2008 | 03:29 PM
txmustang6933's Avatar
txmustang6933
replace your fuel filter and clean your air filter, if you still have the problem, try plugs and wires one may not be fireing. i have also had a similar problem with a 69 stang i had and it was one of the cam lobes rounded so it kept it from firing.
Old Feb 5, 2008 | 03:34 PM
MelloYello's Avatar
MelloYello
Sounds like you have bad O2 sensors
Old Feb 5, 2008 | 04:22 PM
ryan1994mustang
i just replaced the plugs and fuel filter about 3 months ago and i replaced the wires and cleaned the air filter all within the last week and its still doing it. and when i crank it sometimes, the idle will jump up to about 1600 for about 15 secs and then drop back down to normal. while the idle is up, the CEL will come on, but its never on after i drive it anywhere to get it checked so it doesnt throw any codes. i wouldnt need a new fuel filter after just a few months of driving would i? and im sure the plugs havent gone bad yet.
Old Feb 6, 2008 | 09:37 AM
txmustang6933
what about the coil packs? it would only take one not fireing to cause it, the idle kicking up, i had that problem in a 94gt and 95 cobra and i think it was because i didnt have a factory cam. the 94 quit doing it when i found i had a cracked harmonic balancer. no your filters should still be good. i'd check your plugs to see if any look different then the rest. does it backfire through the intake or exhaust?
Old Feb 6, 2008 | 09:40 AM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
94's don't have coil packs.
