Timing question
Old Mar 29, 2005 | 08:12 PM
fasteddie's Avatar
fasteddie
Default Timing question
I was setting my timing at 10btc and the car ran really lousey and so I move it to maybe 20btc and it sounds better. What do I have wrong here, do I need to move the distributor gear one tooth? I did remove the spout plug to do this.
Thanks!
Ed
Old Mar 29, 2005 | 08:54 PM
luckythirteen13's Avatar
luckythirteen13
Default RE: Timing question
you sure your using the number 1 cylinder to time it?
Old Mar 30, 2005 | 08:56 AM
Djs94stang's Avatar
Djs94stang
Is this stock or with mods....such as a cam?
Old Mar 30, 2005 | 05:22 PM
fordguy17's Avatar
fordguy17
i am about to set my timing and i was wondering which cylinder is number one? is it the front one on the driver's side?
Old Mar 30, 2005 | 08:11 PM
89stanglx's Avatar
89stanglx
front cylinder on the passenger side is the one you want. The #1 Cylinder
Old Mar 31, 2005 | 05:35 PM
import slayer's Avatar
import slayer
....and I doubt you have 20* initial timing also. The starter would never crank the engine with that much initial timing.
Old Apr 1, 2005 | 01:39 PM
Chopper's Avatar
Chopper
You can do a down and dirty timing job by setting the timing at some setting that gives a good idle,then take 'er for a ride.If it doesn't knock under acceleration,pull over and turn it a little more.Repeat untill you get a knock under hard acceleration then back off a degree at a time untill the knock goes away.You can then get out the timing light and see what the timing is now set at.
CarrieS
Sep 1, 2015 01:00 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
Calizic
Aug 28, 2015 01:46 PM
stormesixx
Aug 25, 2015 09:11 AM
ding56
Aug 14, 2015 02:40 AM
