Koeo test question...
Old Mar 29, 2005 | 09:20 PM
90Mustangfan's Avatar
90Mustangfan
I ♥ Acer
Default Koeo test question...
Ok when I do the test heres exactly what happen. I turn the key to On. the I get a real quick flash(doesnt mean anything) then I get a flash, then 3-4 seconds later get another flash. then about 3-4seconds later I get a flash. and 3-4 seconds later I get a flash. then heres an 8-10 second pause i get 1 flash, then 3-4 seconds later I get 3 flashes, thenpause and then ge 4 flash for code 34. My question is the first 4 flashes Does that ean code 11? then does it mean that the code 34 is in the continues menory codes or is that the actual codes?heres what it looks like
flash=/
pause= - each - represents 1 second
/quick flash----/---/---/---/------/------///--////--///--////--------------end of test.
Old Mar 29, 2005 | 09:32 PM
96SilverLT1's Avatar
96SilverLT1
Default RE: Koeo test question...
That means that your getting a "system ok" for KOEO but retirving a code 34 as a memory code. The memory codes are seperated by a 6 second deley
Old Mar 29, 2005 | 10:18 PM
90Mustangfan
I ♥ Acer
So that doesnt mean that the actual sensor is bad? or does that mean it wasnt working at 1 point in time a while ago. will it matter if I had the battery disconnected last?
Old Mar 29, 2005 | 10:36 PM
96SilverLT1
you could clear the codes and see if it comes back...
Old Mar 30, 2005 | 12:03 AM
90Mustangfan
I ♥ Acer
How do you clear the codes for the contineus memory?
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
GT350 S550 Tech
Sep 29, 2015 03:29 PM
