if it's only in second or third gear, my car does it to. I heard it was the shifter or something else in the tranny. It's not big deal. My friends car does it too.
mine did that for a while and then stopped on its own. people thought i had a blower. i think it was a vaccum leak, check around the intake area for vaccum leaks. I think some MAF and CAI's make a whistling noise. my pro m bullet whine a little bit while cruising.
Also depends on your intake.. My Trick Flow intake whistles like a blower, sounds kind of cool though, and when I shut off my engine, you can hear all of the air rush out of the intake..
i have a bigass flex-lite fan that sounds like a blower too. Maybe u have an aftermarket fan. But it could be all these things....probably the trickflow intake is the answer.
My alternator bearing makes the same noise as a blower and people think im chaged all the time. I know this sounds bad, but ive ran the same alternator for the last 20k miles and the bearing hasnt gone out yet. i kinda like it, but it is like false advertising.
mine does this also, but it may be because the oil in my A/C is probably gone and I don't have any lines hooked up to the compressor.
my air pump did this too.
