hard to start
Old Mar 30, 2005 | 05:25 PM
white 98 gt's Avatar
white 98 gt
Default hard to start
hello everyone, here's a tricky one for you. car has 108,500 miles. runs fine, idles slightly rough, but drives ok. no hesitation, etc. hard to start after sitting awhile. cranks & cranks till it starts. does this hot or cold, doesn't matter. just put new iac on today. engine is stock. is this just characteristic of this engine? started this at about 60,000 miles. no check engine light. plugs & wires are maybe 1- 1 /2 years old.(motorcraft) any ideas whatsoever? getting frustrated with this. thanks for the ideas in advance. have looked in previous posts, but most mention the iac, which i replaced. thanks again.
Old Mar 30, 2005 | 06:02 PM
fordguy17's Avatar
fordguy17
Default RE: hard to start
whens the last time you did a thorough tune up? (oil change, fuel filter, air filter, plugs, dizzy cap, etc._
Old Mar 30, 2005 | 07:17 PM
white 98 gt
hey ford guy, new plugs & wires @ 85,000 miles. air filter last summer, fuel filter a year ago. think maybe coil packs are causing it?
Old Mar 30, 2005 | 11:27 PM
fordguy17's Avatar
fordguy17
go ahead and replace the fuel filter. it might be gummed up from some bad fuel or something. also dump a bottle of fuel injector cleaner into your tank next time you get gas. can you hear the fuel pump prime the motor when you turn the key to the run position?
Old Mar 30, 2005 | 11:44 PM
trumpet112001's Avatar
trumpet112001
fill up on Shell "V" power and see if that helps...you never know.
StalkerGT
Sep 25, 2015 02:41 PM
Dragonus18
Sep 9, 2015 01:21 AM
5.0 kevo
Sep 3, 2015 06:24 PM
cbird1177711
Sep 2, 2015 04:12 PM
