Cleaning fuel injectors?
Old Mar 31, 2005 | 06:29 PM
philly3384's Avatar
philly3384
Default Cleaning fuel injectors?
What is the best way to clean out my fuel injectors?
Old Mar 31, 2005 | 07:47 PM
philly3384's Avatar
philly3384
Default RE: Cleaning fuel injectors?
some one please? lol
Old Mar 31, 2005 | 07:53 PM
Demon_Mustang's Avatar
Demon_Mustang
Give it time, someone will reply.
Anyway, I haven't done it myself, but do you want the best way or the easiest way? I'm sure the easiest way is by some kind of gas additive, and the best way is to take them out and brush them with some kind of solution that would dissolve impurities, something like mineral spirits or something, lol, or just some carb cleaner...
Old Mar 31, 2005 | 07:55 PM
stanglx2002's Avatar
stanglx2002
you could use brake cleaner and a brush it with a toothbrush lightly
Old Mar 31, 2005 | 09:29 PM
86HOGT's Avatar
86HOGT
At the college they have this machine that takes the car's fuel pump and tank out of the picture entirely and runs the injectors through its gas/cleaner mix for like 15 minutes, that's the best way. Find a shop with one simular and never look back.
Old Mar 31, 2005 | 10:16 PM
birdman076's Avatar
birdman076
You can find a shop that reverse flow cleans the injectors as this will also clean the filter in the injector as well, or do what I did. When I swapped to the new style 4 hole disc type I cleaned them all with laquer thinner and a tooth brush. I used an old armor all bottle to spray the laquer thinner into the injector and it dripped out the bottom pintle, I kept spraying until it ran clear, and it took off all the varnish and built up grime. It works great and wont eat the rubber O rings unless you leave them submerged in it for a few days and then it just swells them lol.
EZFEED
May 5, 2016 08:54 PM
pimp2303
Sep 17, 2015 08:45 PM
SteelerNation82
Sep 16, 2015 07:11 AM
TfcCDR
Sep 14, 2015 12:08 PM
5.0 kevo
Sep 3, 2015 06:24 PM
