How chips work
Old Mar 31, 2005 | 09:01 PM
That Guy's Avatar
That Guy
Default How chips work
So i've got my exhaust done and no longer have cats. Of course now the check engine light is on. I want to have that turned off. From what I understand I need a new chip in order to do this. If i'm getting a chip I also understand that I can bump up my timming and not have to get a timing adjuster. However, I don't know the differnce between tunners and chips and how they work. I've seen some chips on ebay from anywhere from $10 to $50. i don't want to get somethig cheap but if I don't have to pay $400 to turn off my check engine light and maybe get a little performance I would want it.
Old Mar 31, 2005 | 10:23 PM
luckythirteen13's Avatar
luckythirteen13
Default RE: How chips work
dont buy any chip that isnt a brand name. so no ebay chips. most of them are just resistors that f*ck with your maf.
chips and tunes do pretty much the same thing. a tuner is hand held and usually has multiple settings which you can change when you want. a tuner reprograms the stock computer.
a chip attaches to the computer and takes in all the readings from the sensors and then tells the computer what to do to make more hp.
both usually just alter fuel curve and add a little timing. the tuners though can remove rev limites and governers on speed
Old Apr 1, 2005 | 01:51 AM
That Guy's Avatar
That Guy
So where do i get a chip and how much is the price of most chips. To me, spending $400 on a tuner is a lot buck and not as much bang as pullies and maybe some more intake work. I figure if I could get a chip for less than half than that, I could get the Check Engine Light off and the timing moved up I would be better off. What do you guys think?
Old Apr 1, 2005 | 10:50 AM
Ontherocks98's Avatar
Ontherocks98
www.rpmoutlets.com
www.mustangtuning.com
www.v6mustangstuff.com
Old Apr 1, 2005 | 10:56 AM
nanaki's Avatar
nanaki
Retired MF Moderator
MIL
Old Apr 1, 2005 | 01:36 PM
YinYangStang's Avatar
YinYangStang
ORIGINAL: nanaki
MIL
yah, very helpful...look into mil elimanators, they'll shut off your check engine light since you don't have cats
Old Apr 1, 2005 | 08:47 PM
That Guy's Avatar
That Guy
So what you guys are telling is that I'll get more HP out of spending my money on a timing adjuster and pullies rather than a $400 chip? If I'm spending $400 and only getting a minimal gain vs large gains with other mods why would I get a chip?
Old Apr 2, 2005 | 12:12 AM
SpecterGT260's Avatar
SpecterGT260
ORIGINAL: That Guy
actually, the tuner is what is going to bring out the best in all of those parts. On a stock motor, a tuner basically be just a buttony piece of plastic u have laying around. You get your power when you combo it with mods. Get u an intake, plenum, and headers and u will be amazed.
Old Apr 2, 2005 | 12:47 AM
slo93aod's Avatar
slo93aod
you probally wont see any performance gain out of a chip on a stock car, unless it sc'd
Pyrate Dave
Sep 10, 2015 07:30 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
cbird1177711
Sep 3, 2015 08:43 PM
Sep 1, 2015 08:16 PM
