Driver's window seal
Old Feb 23, 2008 | 08:59 AM
mcfarway's Avatar
mcfarway
Default Driver's window seal
Latelymy driver's side window doesn't seal in the upper-rear corner when I shut the door. If I'm shutting it from the outside, I can close the door by pressing on the upper-rear corner & it seals fine. If I'm inside the car, after closing the door I have to roll the window down, then back up to get it to seal. I haven't done anything to my car/door ... maybe somebody messed with it (trying to break in)? If anyone can help me figure out how to get the windowrealignedI'd appreciate any/all advice.
Old Feb 23, 2008 | 09:32 AM
BLK89GT's Avatar
BLK89GT
Default RE: Driver's window seal
im not sure if your door pin bushings are like the fox body but on the door hinge if the bushings that hold the pins in place are bad thats probably ur problem. thats somthing you can look into. or it might be somthing as simple as your window being off track or somthing is loose. i would start there. hope that helps some
cr620
Oct 3, 2022 10:18 PM
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
bradleyb
Nov 27, 2015 07:50 PM
guitarman376
Sep 30, 2015 05:54 PM
