LEAK?
Old Apr 3, 2005 | 11:53 AM
stanglx2002's Avatar
stanglx2002
Default LEAK?
I think i know what my problem is bc when my car is running i can hear a high pitch sound. It sounds like i have a vaccum leak somewhere. My question is how do i find the leak?
Old Apr 3, 2005 | 03:49 PM
primetime5.0's Avatar
primetime5.0
Default RE: LEAK?
others say to spray the vacuum lines with carb cleaner to see if there leaking
Old Apr 4, 2005 | 01:07 AM
88GT40's Avatar
88GT40
Default RE: LEAK?
what you would hear from a vacuum leak would be a hissing noise like air through a tube, you can use a short tube, vacuum line or something similar and hold it up to your ear as you probe along the vacuum lines while the engine is running, thats the hard way, or you can spray carb cleaner on all the hose ends and the areas between the upper to lower intake and listen for the idle to rise.
Old Apr 4, 2005 | 01:08 AM
dc_mann8's Avatar
dc_mann8
Default RE: LEAK?
still have smog? check its lines, one of mine has a hole in it and sounds like that
Old Apr 4, 2005 | 02:07 PM
stanglx2002
Default RE: LEAK?
i dont think i have a vaccum leak bc i hear a high pitch noise when its cold but when it warms up it goes away and idle fine. i know one of my problems is the TPS bc the setting is at 4.92 volts and it wont come down and i have tried everything i can think of.
Old Apr 4, 2005 | 05:36 PM
babygurl2000's Avatar
babygurl2000
I ♥ Acer
Default RE: LEAK?
ahh the dreaded high pitched whistling noise..ive been trying to figure this out too remember?
Old Apr 4, 2005 | 09:42 PM
88GT40's Avatar
88GT40
Default RE: LEAK?
replace the tps it's cheap like 30 bucks, but i cant figure on how it would be making any noise occur
Old Apr 4, 2005 | 09:47 PM
roundman's Avatar
roundman
Default RE: LEAK?
a high pitched whine could be the bearings in the alternator beginning to fail. remove the drive belt and run the engine a bit to see if the noise goes away. if it does, then it's a bearing on something being driven by the drive belt. if not, then it could be a vacuum leak or pressure leak from the smog pump.
Old Apr 5, 2005 | 12:39 AM
stanglx2002
Default RE: LEAK?
im going to check for leaks tom and do a KERO test too
4cylinderplus2
Oct 9, 2020 07:45 PM
bradleyb
Nov 27, 2015 07:50 PM
jerrytubes
Oct 23, 2015 12:11 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
wraith777
Sep 28, 2015 10:49 AM
