Clutch and trans
Old Feb 26, 2008 | 09:27 AM
just1fix's Avatar
just1fix
Default Clutch and trans
Hey, need 2 know bout a clutch spring return? Is there supposed to be 1 on my '91 with a t-5? And why not? Wouldnt it keep the throw out bearing off of the pressure plate? Also, the freakin speedo gear on the output shaft moved on me. Do I need to remove the trans for this fix? Has anyone else had this problem?
Old Feb 26, 2008 | 09:43 AM
ericburt's Avatar
ericburt
Default RE: Clutch and trans
does the throw out bearing sqeal when clutch isnt pushed in?
Old Feb 26, 2008 | 09:53 AM
just1fix's Avatar
just1fix
no, dont hear any noise really, still tuning car in, what i thought was the throw out bearing was actually spark knock. Just being a dumptruck mechanic, all of my trucks have return springs, and i have actually seen a throw-out bearing wear thru a pressure plate!
Old Feb 26, 2008 | 04:17 PM
Jfsram's Avatar
Jfsram
The throwout bearing stays on the pressure plate fingers. Don't worry about a return spring.
Old Feb 27, 2008 | 09:52 AM
just1fix's Avatar
just1fix
Thanks.
Thunderball
15
Nov 22, 2015 11:49 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
junior04
Sep 28, 2015 10:53 AM
wraith777
Sep 28, 2015 10:49 AM
