Locks and Light
Old Feb 29, 2008 | 02:59 PM
akp20032004's Avatar
akp20032004
Default Locks and Light
One morning my power locks quit working, and remote. No bad fuses, but now they lock when the car is turned on but not when it's off or turned on accessory. When I push the unlock the dash lights come on, but go off when I release the button, and no sign of the lock trying to work at all. It also makes the chime come on if the keys are in the ignition and the door is open, but the chime doesn't work if the button is not pushed. Now my dome light doesn't come on at all. NO IT"S NOT BURNED OUT, my car is equipped with the anti-theft crap, including the dome light coming on when I open the door, but now no longer works at all. Any ideas?
Old Mar 1, 2008 | 09:52 AM
99_GT's Avatar
99_GT
Default RE: Locks and Light
I would ponit to the Keyless/Remote Mod.
Does the trunk unlock button in the car work when the car is off?
When the car is off will the dome light come on when you turn the main light switch to dome?
If they both work then you should have the power to the module.
Do the locks work fine when running?
Old Mar 1, 2008 | 11:14 AM
akp20032004
ORIGINAL: 99_GT
No the remote does not function at all and the dome light will not come on at all. The locks will not work unless the car is running but the locks will only lock.
Old Mar 1, 2008 | 01:16 PM
99_GT's Avatar
99_GT
I would replace the battery in the remote
first.
Old Mar 1, 2008 | 04:54 PM
akp20032004
ORIGINAL: 99_GT
first.
I Tried That. It's fine, I tested it at autozone. There is something else totally wrong.
jwog666
Dec 27, 2021 08:09 PM
folivier
Oct 2, 2015 05:34 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
logan409
Sep 26, 2015 07:43 PM
Sep 25, 2015 06:58 PM
