tapping noise...? puzzled!!!!!!
Old Apr 4, 2005 | 09:51 PM
dh324's Avatar
dh324
Default tapping noise...? puzzled!!!!!!
Every time i drive my 01 gt when its cold i get this tapping noise almost like a metal vibration or like something is loose when i hit about 2500-3000 rpm and from there it get louder the higher i rev any ideas on what the hell it could be. Ive put it up on a lift at my work and went all though it with a rubber hammer hitting the underneath hopin to hear it but it only happens when i drive it. like i said it sounds like something is loose and vibrating like a bracket or a clamp......im completely stumped
Old Apr 5, 2005 | 01:07 AM
luckythirteen13's Avatar
luckythirteen13
Default RE: tapping noise...? puzzled!!!!!!
loose rockers?
Old Apr 5, 2005 | 01:16 AM
86gt5.0HO's Avatar
86gt5.0HO
Cat heat shields?
Old Apr 9, 2005 | 12:04 PM
dh324's Avatar
dh324
Checked all of these put the car up on a lift and took a rubber hammer and started at the front of the car and worked my way back but still nothing..it only does it when im driving. I tried driving it while it was on the lift and it didnt make a sound either.
Old Apr 9, 2005 | 01:28 PM
luckythirteen13
have you checked for an exhaust leak. exhaust leaks sound metal
Old Apr 9, 2005 | 08:04 PM
roundman's Avatar
roundman
are you sure that the engine is not pinging or detonating?? since it only seems to happening under a load, this is what I guess it is. or you running low octane gas with the timing set too high???
Old Apr 10, 2005 | 12:26 AM
88GT40's Avatar
88GT40
sounds like the same problem i have, you prolly have a blown header gasket, I dont hear it until i give it gas and it gets louder as i hit higher revolutions.
Old Apr 13, 2005 | 07:18 PM
dh324's Avatar
dh324
well i guess ill find out this weekend im installing my bbk lt ceramic headers and my h-pipe. If it does it after that who knows what it is.....ill have to keep checking. Although i dont think its that cause ive put it on a lift at my work and went throught the gears in the air and it didnt make a sound...?
jwog666
Dec 27, 2021 08:09 PM
yourmom6990
3.7L V6 Technical Discussions
Oct 14, 2015 10:08 PM
accarter
Sep 21, 2015 11:56 PM
stark777
Sep 21, 2015 12:46 PM
fastbackford351
Sep 12, 2015 09:42 AM
