what the hell does a MAF do?
Old Mar 5, 2008 | 05:25 PM
dstecklair78's Avatar
dstecklair78
Default what the hell does a MAF do?
what is the purpose of the MAF and whats the point to having a bigger one? what do they mean when they say it meter gets peged?
Old Mar 5, 2008 | 05:31 PM
GreyStang's Avatar
GreyStang
Default RE: what the hell does a MAF do?
MAF measures how much air is flowing into the engine
Old Mar 5, 2008 | 05:36 PM
floodzilla's Avatar
floodzilla
A bigger MAF compensates the computer to still run right with bigger injectors.
Old Mar 5, 2008 | 08:59 PM
Tha Boss's Avatar
Tha Boss
Mass air flow measures the amount of air so that the computer can put the amount of fuel that is needed.
Old Mar 6, 2008 | 08:49 AM
w8less's Avatar
w8less
ORIGINAL: Tha Boss
pretty much.
Old Mar 6, 2008 | 09:34 AM
groundpounder's Avatar
groundpounder
Sith Lord/Site Mod
to put it a bit more technically
The MAF (Mass Air Flow meter) measures/tracks/meters the amount of airentering the engine and sends that information to the ECM (engine control module) so that the ECM will send the right message to the injectors so that they will pulse (inject) the proper amount of fuel into the cylinder to mix with the air and efficiently combust
the point of having a bigger one is that if you can move more air, sending a 'larger' message to the ECM for more fuel from the injectors, you make more power
when it pegs, basically it means that the injectors cannot send any more fuel than the MAF calls for.
Hope this helps.
Old Mar 6, 2008 | 12:19 PM
03GTVert's Avatar
03GTVert
A bigger MAF will flow more air, but putting one on a stock engine is pretty useless because the stock MAF flows plenty of air. A bigger MAF is only needed after heavy mods like a supercharger or turbo etc.
Old Mar 6, 2008 | 06:32 PM
dstecklair78
i already have a factory supercharger on my saleen, i ordered a 90mm MAF do i have to upgrade the injectors and fuel pump?
Old Mar 6, 2008 | 11:27 PM
03GTVert's Avatar
03GTVert
ORIGINAL: dstecklair78
Only if you're also upping your boost and even then your injectors and fuel pump might be fine, it depends on how much boost you're adding.
Old Mar 11, 2008 | 05:51 PM
1988GTstang's Avatar
1988GTstang
i couldnt have said it better myself groundpounder
