coolant light????WTF???
Old Apr 6, 2005 | 01:41 AM
nathansmith50's Avatar
nathansmith50
Default coolant light????WTF???
i have a 2000 GT and every now and then the coolant light comes on.....it'll stay on for a couple days and then it'll go off for a day or two then come back. in the winter it comes on every time i start the car. but then if it warms up a bit and i turn it off and start it back up it doesn't come on. anyone ever heard of this?
Old Apr 6, 2005 | 01:48 AM
SXGT's Avatar
SXGT
Default RE: coolant light????WTF???
that means your electric fan is off , look under your hood when its on, mine is currently doing that. losers installed a new electirc fan motor and wires and must have goofed
Old Apr 6, 2005 | 01:54 AM
nathansmith50
if the fan was off shouldn't it start to overheat? it never does.
Old Apr 6, 2005 | 01:55 AM
SXGT's Avatar
SXGT
you would think that, but mine didnt tonight when i was driving 7+ miles then it kicked back on.
Old Apr 6, 2005 | 02:24 AM
Acer2428's Avatar
Acer2428
Site Mod
Mine does that sometimes... I just shut the car off and tunr it back on again and the light goes away... Eventually I did have to add more coolant though, so don't ALWAYS ignore the light.
Old Apr 6, 2005 | 02:46 AM
nathansmith50
might be a defective connection or fan then? the light does stay on literally for days at a time. i remember it staying on for the duration of a trip from here to MI (about 550 miles)
Old Apr 6, 2005 | 03:27 AM
steeda_exhaust's Avatar
steeda_exhaust
i have to ask the obvious question as you did not say....
is youre coolant low?
could be the low coolant sensor itself as well.
Old Apr 6, 2005 | 03:49 AM
mikev08826's Avatar
mikev08826
I ♥ Acer
Um...Take this for what it's worth. Not sure if this makes sense, but...
2000's are notorious for intake manifold leaks...Is it leaking???
Old Apr 6, 2005 | 04:11 AM
Acer2428's Avatar
Acer2428
Site Mod
ORIGINAL: steeda_exhaust
Hahaha...I was going to ask, but I was afraid of being flamed....hahaha
Old Apr 6, 2005 | 09:46 AM
Texas 67's Avatar
Texas 67
The coolant is just a bit low and is turning the light on. The tank you put coolant into is called a surge tank. The coolant surges from the radiator to the tank and causes the level to fluctuate. This is the reason for the light coming on. Just add a small amount of 50/50 mix and call it good.
