hot center console?
Old Apr 6, 2005 | 11:46 PM
usernamesarelame's Avatar
usernamesarelame
Default hot center console?
I've had my mustang for about 3 weeks, and i just noticed that the center console gets HOT while driving, like, hot to the touch. i have a steeda short shifter in the car, and i know there is pretty much NO material between the plastic trim around the shifter, and the underside of the car... i figured that maybe the aluminum from the shifter is transfering a lot more heat through the console than the stock shifter would. But, i just dont know. so, has anybody else experianced this hot console problem? is it normall???
thanks
-kevin
Old Apr 7, 2005 | 02:11 AM
GIGM08GT's Avatar
GIGM08GT
Default RE: hot center console?
ive noticed that it gets warm right around where the tranny is but nothing too severe.
Old Apr 7, 2005 | 10:45 AM
snlpa's Avatar
snlpa
My shift *** gets a little warm....not the console though?
Old Apr 7, 2005 | 11:28 AM
Chopper's Avatar
Chopper
My Pro 5.0 shifter uses the rubber inner boot cut to fit around the shifter body.If the Steeda part doesn't use this that's probably the trouble.
Old Apr 7, 2005 | 12:38 PM
Mr03mach1's Avatar
Mr03mach1
You can thank the 4 cats that are tucked along both sides of the console......
Sometime I swear my sneaker is going to catch fire.
Old Apr 7, 2005 | 12:47 PM
GIGM08GT's Avatar
GIGM08GT
O ya now I remember on the Drive to Texas I had to keep checking to see if the heat was on. Ya that normal. Pretty sur that the X pipe will move that cats back farther. Thats my suggestion
Old Apr 7, 2005 | 02:36 PM
Djs94stang's Avatar
Djs94stang
My console always got warm especially around town. There is very little or no insulation under the console. The heat is from the floor which is ultimately from the exhaust sitting right under it. The car would have benefited from a heat shield in the tunnel but stangs are built economically...not alot of extra like that.
Old Apr 7, 2005 | 08:49 PM
pipeliner's Avatar
pipeliner
Bring some hot dogs and cook them why you are driving
Old Apr 7, 2005 | 10:06 PM
xRockThePonyx's Avatar
xRockThePonyx
Mine gets a bit warm sometimes, but only when I'm driving around a whole lot.
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
