2003 GT boost pressure?
Old Mar 10, 2008 | 10:54 PM
chefboydrd's Avatar
chefboydrd
Default 2003 GT boost pressure?
what is the max psi my 2003 gt can handle? it is stock with the exception of highflow intake and exhaust
Old Mar 11, 2008 | 02:53 AM
tbirdscwd's Avatar
tbirdscwd
Default RE: 2003 GT boost pressure?
I wouldn't run anything above 9-10 psi on a stock 4.6 2v. Anything above that, they tend to start having real problems, like "need a new engine" type of problems. With ported heads, blower cams, and other supporting mods you should be able to achieve around 450rwhp "safely" with a good tune, but nothing is guaranteed on the stock bottom end. Mine blew a ring land at 400rwhp on a safe tune.
Old Mar 11, 2008 | 06:47 AM
GreyStang's Avatar
GreyStang
I think you also need to keep careful attention to boost temperature. The hotter the charge the less PSI you should be using on a stock engine. Maybe 9-10 would be OK withintercooled boost, but 6-8 if not intercooled
Old Mar 11, 2008 | 10:13 AM
tbirdscwd's Avatar
tbirdscwd
Correct, I forgot to mention that is when intercooled. Although, there are a couple people on here running 9-10 psi non-intercooled without any issues, I wouldn't want to try it.
Old Mar 13, 2008 | 07:16 PM
hot wheels's Avatar
hot wheels
9lbs. non intercooled, runs like a charm BUT, getting the aftercooler put on this spring with a little more boost.
jwog666
Dec 27, 2021 08:09 PM
TCStangerv6
Oct 11, 2015 05:57 PM
svfetter
Oct 5, 2015 11:39 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
junior04
Sep 28, 2015 10:53 AM
