points distributor problem
Old Apr 8, 2005 | 06:09 AM
woedend's Avatar
woedend
Default points distributor problem
Ok I have a 90 mustang engine(302) set up on points style dist. and carbed. It runs fine when the distributor is in and barely tightened, but when you tighten down the bolt that holds the dist in place the engine stalls. I thought it could be binding but when it's loose and running good, it will also stall if you put a little pressure on it toward the passenger side, not a lot, just a finger on it pushing that way will stall the engine. The dist looks new, has a new gear and shaft on it, and a new cap. It's all hooked up right obviously because it runs perfectly when it's loose. Any idea what the problem could be?
Old Apr 8, 2005 | 10:46 AM
5.0mustang5speed's Avatar
5.0mustang5speed
I ♥ Acer
Default RE: points distributor problem
probaly a ground some where..trash it get a msd, accell, mallory...etc..it will will 10 times better with much easier start ups and probaly better gas milage and definely better performance....points are 1960;s techonolgy
Old Apr 8, 2005 | 11:40 AM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Yup points are garbage and will hurt perfomance above 5000 rpm, they bounce. It could be a ground but it also could be a bent shaft. Get a new MSD dist. and convert to full electronic ignition it will run better.
mungodrums
Oct 7, 2015 04:01 AM
StalkerGT
Sep 25, 2015 02:41 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
zanemoseley
Sep 6, 2015 12:58 PM
5.0 kevo
Sep 3, 2015 06:24 PM
