93 351W rebuild
I have a 351W out of a 93 F-250 Im thinking about rebuilding, i want to get as much possible bang for my buck and still have a reliable engine. here are some parts ive been looking at:Speed-Pro Duroshield Competition Series Rod Bearings
Rod Bearings, Performance, Standard Size, Duroshield Coated Alloy, Ford, 351W, Set of 8
3/22/08 $94.99
Speed-Pro Competition Series Main Bearings
Main Bearings, Competition Series, 3/ 4 Groove, Standard Size, Tri Metal, Ford, 351M/ 351W/ 400, Set of 5
Tomorrow $59.95
Dura-Bond High Performance Coated Bearings
Cam Bearings, Performance/ Race, Bi Metal, Fluoropolymer Lead-Based Micro Babbitt, Ford, V8, Small Block, Kit
3/12/08 $59.95
ARP High Performance Series Wave-Loc Connecting Rod Bolts
Connecting Rod Bolts, High Performance Wave-Loc, 8740 Chromemoly Steel, Ford, 302/ 351, V8, Set of 16
Today $56.88
Trick Flow Track Max Hydraulic Roller Camshafts for Ford 5.0L
Camshaft, Track Max, Hydraulic Roller Tappet, Advertised Duration 275/ 279,Lift .499/ .510,Ford,Small Block,Ea...
Today $159.95
Lunati Hydraulic Roller Lifters
Lifters, Hydraulic Roller, Vertical Link Bar, Ford/ Lincoln/ Mercury, Set of 16
Tomorrow $138.39
Lunati Performance Replacement Pushrods
Pushrods, Replacement, Steel, Heat-Treated, 5/ 16 in. Diameter, 8.144 in. Length, Ford, Small Block, Set of 16
3/24/08 $98.39
COMP Cams Pro Magnum Roller Rocker Arms
Rocker Arms, Stud Mount, Full Roller, Steel, 1.6 Ratio, Fits 3/ 8 in. Stud, Ford, Small Block/ 351W, Set of 8
3/21/08 $145.95
Summit Cast Crankshafts
Crankshaft, 2-Piece Seal, External Balance, Cast Steel, Standard Snout, Ford, Small Block, Each
Today $429.95
Summit Racing Street & Strip Billet Distributors
Distributor, Magnetic Pickup, Mechanical Advance, Black Cap, Ford, Small Block Windsor, 351W, Each
Today $209.95
Manley Street Flo Valves
Valves, Exhaust, Stainless Steel, 1.550 in. Diameter, Ford, Small Block, Set of 8
Today $79.60
Valves, Intake, Stainless Steel, 1.850 in. Diameter, Ford, Small Block, Set of 8
Today $79.60
EMP Stewart Stage 1 Water Pumps
Water Pump, Stage 1, Cast Iron, Natural Finish, High Volume, Reverse Rotation, Ford, Small Block, Each
3/14/08 $74.95
Summit Oil Pump and Pickup Kits
Oil Pump and Pickup Assembly, High-Volume, Ford, Small Block, Kit
Today $85.95
Total Seal Street/Stock Piston Rings
Piston Rings, Chrome, 4.030 in. Bore, 1/ 16 in., 1/ 16 in., 3/ 16 in. Thickness, 8-Cylinder, Set of 8
Today $172.95
thats a list of stuff im thinking of getting so far, im trying to do this for under 2500 or 3000, not including machine work, most these parts are off of summit racing, is there a cheaper place to go? are there better combinations? possibly kits i can get that will have the majority of this stuff? the engine is all original and has never been rebuilt before, and im hopeing the pistons,rods, and heads are still good. id like to go from efi to carbed, im planning to put the engine in a mazda rx7, what other cars will this engine fit in??? any guess of how much hp?
3/22/08 $94.99
Tomorrow $59.95
3/12/08 $59.95
Today $56.88
Today $159.95
Tomorrow $138.39
3/24/08 $98.39
3/21/08 $145.95
Today $429.95
Today $209.95
Today $79.60
Today $79.60
3/14/08 $74.95
Today $85.95
Today $172.95
What do you ultimately want to do with it? You could build an h/c/i 351 with the stock crank(plenty strong for most street car setups), run some decent rods/pistons that are light weight and make quite a bit of power.
I would guess frpp makes a kit or Jegs or Summit to build what you want. Or maybe take a look at the Edelbrock performer RPM kit, I'm not sure what it comes with but it should make pretty goodpower for the street
