I need help with the bore
Old Mar 24, 2008 | 04:37 PM
98BlackStang46's Avatar
98BlackStang46
Default I need help with the bore
Ok guys I have a 1978 351Windsor I just bought.... Well when I pulled the pistons out I found that it was bored .30 over... the block has a little rust in the cylinder walls so its def gonna have to be bored again... If i take the bore on out to .60 over is this gonna be bad? Is the block gonna be likely to split in half cause I plan on pushing around 600hp somewhere between 575-625hp... Is it gonna have overheating or compression probs... Is it gonna lack low end torque... Any info would be much appreciated.. Thanx guys
Old Mar 24, 2008 | 05:51 PM
GreyStang's Avatar
GreyStang
Default RE: I need help with the bore
What does the bore currently measure out to?
Old Mar 24, 2008 | 06:11 PM
98BlackStang46
I have no idea but when I pulled the pistons out they were stamped 30 and someone told me that means its bored .30 over
Old Mar 24, 2008 | 10:45 PM
PJC Racing's Avatar
PJC Racing
You could probably go .040" and be fine. The correct way would be to have the block sonic checked to ensure there is enough cylinder wall thickness left before boring.
But here is what I would do, you don't have a desirable block, those are the 69 through 74, so put it in the back of the garage for a rainy day orswapping material later and get another unmolested block. The frugal shoper can find one for cheap.
Old Mar 28, 2008 | 02:22 AM
98BlackStang46
I looked around forever and couldnt find a 74 or earlier.... Shouldnt this block be enough to hold the HP I wanna run on it??
Old Apr 3, 2008 | 01:26 AM
PJC Racing's Avatar
PJC Racing
Atthat power range you will be pushing it with any stock block. I would go after market first, 69-74 second, mexican (yes they made them/and are very hard to find) third, post 74 block last.
What rpm range do you anticipate? RPM is the biggest stock block killer. The other issue on stock 9.5" blocks is cap walk.
McLeary
Mar 14, 2016 07:50 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
JayGee
Sep 15, 2015 12:41 PM
FivePointToTheOh
Sep 14, 2015 03:35 PM
Faolan65
Aug 27, 2015 06:40 AM
