Mustang Storage preparation Help
Old Mar 31, 2008 | 06:55 PM
duke1234's Avatar
duke1234
Default Mustang Storage preparation Help
I need to store my mustang for the summer months form June thru end of August. It is a 2004 Mustang Converitible. Please help with some preparationso I won't have issues when I try to fire it up in the fall. Thanks
Old Mar 31, 2008 | 09:03 PM
BunnMan's Avatar
BunnMan
Default RE: Mustang Storage preparation Help
Fill it with fuel, add fuel stabilizer in the appropriate amount for your tank size, then drive it around a little to get the stabilized fuel up through the lines and injectors. That will keep the fuel frombreaking downand clogging up the system. Turn the A/C on high during the drive to give the seals and O-rings in the A/C system a dose of lube. Next I'd plug in a Battery Tender. They're only about $25-30 and will keep a trickle on your batt when it needs it to keep it from discharging while not in use. Other concerns shouldn't grab a hold too hard in just a few months. Of course it's always best to garage it or cover with a decent quality cover.
God bless,
-BunnMan
Old Apr 1, 2008 | 08:09 AM
Jfsram's Avatar
Jfsram
Wash and wax it, change the oil and park it. Don't worry about fuel stabilizer for a3 month storage.
Old Apr 1, 2008 | 11:59 AM
duke1234's Avatar
duke1234
The car will be stored in a place that won't have an electric outlet. Is there another option for the battery? Or should i just accept that the battery will die?
Old Apr 1, 2008 | 12:14 PM
Riptide's Avatar
Riptide
Can't you just disconnect the terminals then? If it's 3 months it should hold a decent charge?
Old Apr 3, 2008 | 11:31 AM
duke1234's Avatar
duke1234
I dont know? Maybe that is what I will likely do. Either way, it sucks I have to store it for 3 months.
Old Apr 3, 2008 | 05:55 PM
BunnMan's Avatar
BunnMan
Yeah, if no outlet definately disconnect the batt. Otherwise the batt might draw down so low it won't come back and it will be out of juice in 3-4 weeks anyway. The fuel stabilizer is cheap insurance. I have let things sit for a few months and found some varnishing. You sure don't have to do it, but you might wish you did. I know oyu don't have time for this experiment but if you did...fill a one gal gas can with gas, let it sit for three months undisturbed, at the end of three months go fill a different can with fresh gas. While you have both cans together give them the sniff test. Smell a little different? What do you think the differnece is? ....three months! (and fuel breakdown).
God bless,
-BunnMan
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
Jan 6, 2016 07:03 PM
chain
Aug 17, 2015 08:52 AM
daytooday
Aug 11, 2015 09:22 AM
