5w20 or 5w30?
Old Mar 26, 2008 | 08:32 PM
wahooracing's Avatar
wahooracing
Default 5w20 or 5w30?
I have a 2002 mustang gt. Would it hurt anything to run 5w30 oil in the engine. It requires 5w20, the warranty is up on the car, but will it hurt anything in the engine?
Old Mar 26, 2008 | 09:26 PM
m260gt's Avatar
m260gt
Default RE: 5w20 or 5w30?
i think mine takes 5w30.
Old Mar 26, 2008 | 11:20 PM
avexhype's Avatar
avexhype
does it even matter? i mean its only a 10 point difference. on my daily driver (92 nissan stanza) i always put in different weights and brands with watever i find thats cheap at walmart. Runs like a champ at 227 THOUSAND miles, no joke. It doesnt seem to effect drivability or motor characteristics AT ALL. I run that car hard as hell to boot. Just for thread input though, i run 5w20 fully syn Mobile 1 on my 2000 GT.
Old Mar 26, 2008 | 11:25 PM
tbirdscwd's Avatar
tbirdscwd
I always run 5w20 either RP or Mobil1. 5w30 isn't gonna hurt anything, but I'd use the 5w20 if its available. I believe the switch to 5w20 was an effort by ford to increase MPG.
Old Mar 27, 2008 | 12:03 AM
93_five_oh's Avatar
93_five_oh
i'd stick with 5W20... it's thinner and lubricates better. as long as your oil pressure isn't dangerously low, you're fine.
unless you're racing your car i wouldn't go with 5W30
Old Mar 27, 2008 | 12:38 AM
manuelm's Avatar
manuelm
use the 5w20 if u can. if not the 5w30 isnt going to hurt anything. just make sure if u use a FULL synthetic oil u keep using it. cant go back, well at least your not suppose to...
Old Mar 28, 2008 | 05:34 AM
07 Shelby GT's Avatar
07 Shelby GT
If you are from a extreme cold or extreme hot area you might want to take it into consideration. Extreme hot you will want a little heavier weight...opposite for extreme cold. I believe Ford puts 5W20 in just about all cars for some time now. I think Motorcraft 5W20 is a blend of synthetic and conventional. Other than that I don't think it really matters that much. I go with what Ford recommends and haven't had a mechanical failure in my last 3 stangs.
Old Mar 28, 2008 | 07:29 PM
08 Bullitt 2310's Avatar
08 Bullitt 2310
You might want to do a little research on motor oil.Believe it or not the thinnest oil that you can use is always best.The viscosity difference between the two mentioned at operating temp is enough to cause a rise in oil temp.Sounds funky I know.Do some research,google is a good place to start.You will be amazed at what you find out about oil.
Old Mar 29, 2008 | 12:14 AM
timeformiller44's Avatar
timeformiller44
all 99-04 require 5w 20....5w30 will not hurt car
Old Mar 29, 2008 | 09:58 PM
sfi's Avatar
sfi
iT DOESN'T HURT ANYTHING BUT MY CAR GOT WORSE GAS MILIAGE W/ THE 5W30.
BCATL79
3.7L V6 Technical Discussions
Aug 13, 2015 07:41 PM
landomar2014
Aug 10, 2015 10:12 PM
stangman2354
Mar 6, 2007 07:49 PM
cookiemonster
Feb 10, 2007 11:11 AM
04blkstang
18
Feb 16, 2006 03:08 PM
